Both front and rear wiper blades for Cayenne
Thanks to some on this forum for the clues in getting my wiper blades. I did some research and what I came up with I'm extremely pleased and wanted to share.
It took 2 minutes for both front and rear to replace. For front, pull off the plastic retainer,pull arm away from windshield,rotate blade 180 & slide off. Reverse to install. Don't foget to snap the retainer back on. (credit to http://www.6speedonline.com/forums/member.php?u=88594) for wording. No tools required for front or rear. Rear just pull up and out on lower half of blade and it unclips from the holder. new one snaps right back in. Picture on box shows it.
I just bought 2 sets of fronts and rear blades from Autohaus and they are perfect. The rear is a bit longer which I prefer, but not too long. The fronts are OEM identical and so happy to see that. Both made by Bosch, front in Belgium, rear in China.
The cost of 2 sets was less than a dollar over the $75 minimum for free shipping! Highly recommended AutohausAZ. Will put 2nd set in garage for later. The new blade is to the left of the old blade in the picture on the hood.
Received 1,141 Likes
Yes - you might mention 2011 to current model. These will not fit the 2003-2010 models.
BTW - lesson I learned the hard way. When you pull the front arm toward you to remove the wiper blade DO put a bunched up towel on the windshield about where the arm would land if it got away from you with the blade off. They are quite capable of breaking the glass. BTDT on a BMW, haven't made that mistake again.
I Have a 2009 model year CS. Looks like the "AeroTwin" blades are out of stock at my local Advance Auto, and within a 200 mile radius. But they have another, called:
Bosch Icon OE Style Beam Wiper Blade, 26"
Part No. 26OE
Any results here? Direct fit, etc.?
Part No. 26OE
