2006 Cayenne Turbo Lowering Links?
Has anyone purchased and fitted the lowering links for the CTT?
Seems like a cheap alternative to drop the stance a little but not sure of any negative implications to the electronics if fitted?
Well that should help. Some say 22's can be a bit hard riding but it would depend how low you go. There are definitely people on the board that have done lowering links. Although some random eBay parts can be a gamble. Might be a good idea to source links from a reputable source.
Mine is with Lowering links.
No problem at all. Could get a little harsh if you go too low.
I also use the shocks in Sport mode and everything is just fine.
BTW i live in Lima Peru and we have crappy roads.
I didn't see any. I measured against the factory (fixed length) ones and made mine a little longer, maybe 5-7mm.. or even less than, it's a been a while so don't know exactly. The longer they are, the lower your vehicle.
After installation and desired height reached i took to the dealer for an alignment to ensure I was dialed in at the most used ride height. Has been great ever since!
