"Check Right Direction Indicator"
Check to make sure the tab that contacts the bottom of the bulb. Common issue. If that's not it, try plugging in the harness right into the back of he headlight while its out, and test the indicator. My turn signal out what a from the harness not connecting all the way from a weak connection. Another common issue. Search Dipped beam for how to trim the harness holder.
