Auto Socks as snow chain alternative?
Hi There,
Headed north to Tahoe in the '08 GTS for winter and will be required to carry chains. Don't want to get winter tires and definitely don't want to ruin my rims with traditional chains. Has anyone had any experience with Auto Socks? They are material based 'traction device' alternatives that are supposedly approved for use in CA.
Alternatively, Does anyone recommend an alternative?
http://www.autosock.us
Thanks in advance!
Thanks in advance!
Hi There,
Thanks in advance!
Thanks in advance!
If you're going to be in Tahoe all season, you're crazy not to get snow tires. You'd need those socks on all 4 wheels anytime there is snow on the road. Summer tires on a GTS wheel - you're going to be stuck in parking lots with a few inches of snow.
![order](https://rennlist.com/forums/graemlins/order.gif)
If you're only going this once, and will never go again - rent a Tahoe. If you're only going once this winter, and will probably go once next winter, buy a used set of snow tires and wheels.
Don't be that guy stuck at a grocery store entrance holding up everyone else because he chose to drive his AWD Porsche with summer tires in Tahoe. Or when you're braking on a back street that happens to stay in the shadows all day, and is still ice covered while everything else is mostly dry. You'll be a 5500 lb hockey puck.
If this was an A/S tire, I'd say get the sock for the front axle, and you'll be good. Might have to use the sock on steep roads with some snow or packed ice, but otherwise you'll be fine. If you had an A/S in the 255/55/18 size, I'd say bring the socks, but I bet you don't need them unless the DOT chain law is up. But, a 295 summer tire? You're fvcking crazy.
