Bike/Ski Rack Options for No Roof Rack Cars
Hi guys,
We put a deposit down for a decently equipped CPO 2012 Cayenne. Only thing I realize it doesn't have are the roof rails which cannot be retrofitted (kind of bizarre an SUV doesn't come standard with them).
So i'm looking to hear (preferably see!) what options are available out there for hauling skis and bikes (not at the same time) on your non-factory roof railed cars.
Pics would be great! Thanks in advance!
It is possible to add a hitch but not roof rails. Suncoast has Porsche hitch for sale but to complete install car need to be programed by dealer. Maybe not necessary if you just want to use hitch only for bike and skies and not towing.
Hitch carrier. I have one for sale in case you're interested. It doesn't carry skis though.
Like this:
http://www.cargogear.com/OneItemInfo...artnum=SFDURA2
Like this:
http://www.suncoastparts.com/product...de=958V6MERTOW
Thanks!
Pics anyone?? I found this hitch system at Suncoast. Is this the only option and how much should it cost to install?
Thanks!
Thanks!
On a positive note, assuming you're looking at a 958, as I understand it the SUV is already pre-wired from the factory, even if the hitch itself isn't there.
Good luck
That's not the only option, but it's definitely the best option. That is the OEM hitch. There are cheaper aftermarket alternatives (like Uhaul), but likely you're not looking at the same tow capacity and quality. It's unfortunate, but it costs a bunch to get installed by dealer. At least a grand in labor... huge variability amongst different dealers for this though, so hunt around a bit. Or even better, maybe can negotiate something in with your current sale. Ultimately, I found a CPO with the hitch option from the factory, but had looked at a few others missing the hitch before this, and was able to work out something with the dealer for pricing of install post-sale. It's not really a DIY either b/c there's programming that will be needed afterwards to enable the various towing features (i.e. enable trailer turn signal lights, disable backup sensors when trailer hooked up, disable lane change assist when under tow).
Good luck
Good luck
Thanks!
Hopefully your dealer will work with you a bit on install cost.
A bike in the trunk may be a bit more tricky, esp. given the fact I have the Luxor Beige interior.
Do you guys use a rubber mat or similar in the trunk?
I had a hitch installed on my 2012 CTT at Rack and Road. They claimed that the aftermarket hitch they installed ($500, including parts and labor) is the same as the OEM. I realize that you do not have R&R in NY, but you may be able to find a comparable dealer/installer nearby; maybe hitchking.com?
