Towing w 04 CTT vs 2011 C S
I love my 04 Cayenne Turbo but thinking of getting a newer 2011 Cayenne S. Towing is easy with the 04 Turbo with air suspension. Since I'm unlikely to find a 2011 S with air suspension can I still tow my enclosed 20' race trailer or will I need to do something special like those suspension leveling bars?
Thanks for any input
Rick
Rick
Glad to hear you've had success with towing the enclosed trailer. I want to go that route with a CTT and my 996. Are you using an all aluminum trailer or one with wood? I feel like you would miss the torque if you got a non turbo.
Tow a 6800 lb dual axle boat and trailer combo with surge brakes no problem with a '11 C S with no air suspension. No hills and limited freeway, but have gone probably 600+ miles without issue to date.
@ rhart :: My understanding is that the leveling bars are a good idea if you tow through windy areas (mountain passes, etc). I've been a passenger in tow vehicles with leveling bar hookups on the tongue of a large enclosed trailer (w/ 2 cars loaded), and it was very stable. I have a lot of experience towing a boat (surge brakes), but not yet with electric brakes & will soon be deciding whether I need a Elec Brake Controller ( like a Tekonsha) P3 or RF) for that activity ( on my 958CTT).
=S
=S
bweSteve.... the electric brake controller isn't optional... you need it if your trailer has electric brakes and you want them to work right. Not a big investment... but don't look at it as a nice-to-have; it's a must-have.
Yes, Thank You BE455,.. in fact you (+ "turbosporsche" & “stronbl”) were all a BIG help over on this other thread…
https://rennlist.com/forums/porsche-...r-cayenne.html
Although Turbosporsche never did report back on how his electrical testing went. He was going to test his pin-outs, and see if he is getting a variable voltage to the trailer brake pin. You had said you thought it was a total 12v signal EVERY time you step on the brakes. So I never heard the final resolve over there.
Through help from stronbl, I WAS indeed able to find the wiring (4 pin plug) in a "gray foam cover” ( as described by stronbl in post #20 under that thread) under my dash. Yes I have the factory tow hitch package option 1D6 (factory wiring, etc).
The under dash 4 pin plug is wired with the following:
- 3 thick wires in the following colors:
o Solid BLUE
o Solid BROWN
o RED with White Stripe
- 4th wire is a thinner BLACK with small Red Stripe
None of my local Indy, nor Dealer have knowledge about this wiring in the 958 ( go figure), so I plan to soon read up on eTrailer doc’s, and figure out how to hook it up myself. If all looks straight fwd, I plan to purchase a Tekonsha P3. I still have 2 months before I need it.
Thanks again for your help.
=S
o Solid BLUE
o Solid BROWN
=S
@ rhart - Hoping this continued discussion on ebrake controller is still within your interest for this thread ( apologies if not).
I just priced out the parts needed ( as shown on the eTrailer instructions)
https://www.etrailer.com/faq-tb-09-0021-Tekonsha.aspx
The VW connector part # 1J0-972-782 - is $9 at my local VW dealer
The wire with blade connector on the end, part # 000-979-228E - is $19 each (2 needed) - Ouch!
alas, I will not be spending $36 ($19*2) JUST to get the blade terminated wires. I can build this from my own garage spare parts.
=S
=S
So, if I have an 06' CTTS with a trailer package installed from dealer (I don't think they came from Porsche with them added but not clear on this) will I have the wire available under the dash also for the break controller?
Great thread, thanks for all the input.
Kufatec has the male connectors (versus pigtails from VW). I ordered them, crimped them directly to the Prodigy harness wires rather than soldered VW pigtails to Prodigy pigtails, a little neater. Their part number 39953. I could not find these standard AMP Timer male connectors anywhere else in the US: not from Wurth, Digikey, etc.
I know this is a way old thread...do you happen to have any of these? It looks like you have to buy a 50 pack -- could pay you a few bucks to ship 8-10 or so if willing...thanks!
