How do 2016 GTS ride heights w/o air suspension compare to with those with.
Hi,
I was wondering how the new GTS with its 20mm lower ride height compare with the air suspension setup?
For example:
Does Air Suspension set to 'normal' height ride a few mm higher than the standard GTS or the same?
Does Air Suspension set to 'lower' height ride the same or even lower than the standard GTS?
Thanks in advance!
For example:
Thanks in advance!
