Auto Dimming rear view mirror
Old Mar 3, 2013 | 08:43 AM
virkdoc's Avatar
virkdoc
Default Auto Dimming rear view mirror
Hi guys
I am fed up of the manual rear view mirror in my Cayenne 2006. Planning to put in an auto dimming mirror.
What all would I need to do, I know I need a power supply and ground....There is already a rain sensor coming behind the mirror....Can we use the power from that?
Does an auto dimming mirror have a sensor somewhere?
Old Mar 3, 2013 | 09:15 AM
CarreraCup03's Avatar
CarreraCup03
Originally Posted by virkdoc
Hi guys
I have two auto dim mirrors that I have been experimenting with. It is not as simple as powere and ground. I cant get them to work properly.
Old Mar 3, 2013 | 10:40 AM
Dennis C's Avatar
Dennis C
Rocky Mountain High
I installed an aftermarket auto-dimming mirror in my 996. It works very well and it was easy yo install. I don't know if they exist for the Cayenne, but it might be worth a look.
Old Mar 3, 2013 | 11:52 AM
virkdoc's Avatar
virkdoc
ok so what exactly do I need...I see a lot of used mirrors on ebay for like $40 or more which have 2 or 3 wires coming out.
What exactly do we need to hook up?
the mirror in my cayenne swivels on a ball mount, so I was thinkin pick one form ebay and mount it and connect power and ground??
Old Mar 3, 2013 | 11:58 AM
TozoM8's Avatar
TozoM8
http://audipages.com/tozo/mirror.jpg
Old Mar 4, 2013 | 12:21 AM
virkdoc's Avatar
virkdoc
found this;
http://www.ebay.com/itm/OEM-2004-200...da2a50&vxp=mtr
How do I make it work?
Old Mar 4, 2013 | 01:10 AM
TozoM8's Avatar
TozoM8
Looks like two wires are ripped out. Use the wiring I posted. A1 power A2 ground A3 reverse A4-A5 for outside mirrors (likely you don't have auto dim outside mirrors either so ignore these two) A6 lights
Old Apr 2, 2013 | 04:25 PM
virkdoc's Avatar
virkdoc
tozo your diagram shows power and ground..What about switched power?
Maybe one is for switched power and one fore outside mirrors.
Old Apr 2, 2013 | 05:27 PM
TozoM8's Avatar
TozoM8
The power is "hot in run and start"
Old Apr 3, 2013 | 08:21 PM
virkdoc's Avatar
virkdoc
Which means?
Old Apr 3, 2013 | 11:01 PM
TozoM8's Avatar
TozoM8
Switched power. Ignition off = autodim off.
Old Apr 4, 2013 | 01:20 AM
virkdoc's Avatar
virkdoc
Tozo, carreracup used your wiring and his mirror does not work. He says pressing the button does not make the light go off!!
Old Apr 4, 2013 | 01:23 AM
virkdoc's Avatar
virkdoc
This is what is happening to Carreracups mirror:
"I cant remember what I did. The mirror would dim and you could not turn off dim with the switch. So the mirror would dim even if light was not shined onto it, and the power switch had no effect on this. The green light (I think it was green) would not turn off with the switch"
Old Mar 30, 2015 | 03:04 PM
BobbySpeed's Avatar
BobbySpeed
Anyone ever figure this out?
I was told I couldn't install the auto headlight switch and make it work by 2 dealers, but I did and it and the coming home function work perfectly.
Old Mar 30, 2015 | 03:42 PM
magicfan's Avatar
magicfan
I am also fed up with this auto dimming mirror business. Is there any way it can be done? There are bluetooth mirrors that can be charged using the cigarette lighter charger so is there any sort of auto dimming mirrors like this that can be charged like these?
