04 Cayenne Turbo transfer case goes into neutral
The transfer case goes into neutral while driving randomly. I forget the message when this happens, but I have to pull over, put it in park, turn off the car, restart the car, put it in neutral and then move the transfer case setting back to highway. That solves the problem but as you can imagine its a bit unsettling to be driving along and lose all power to the wheels, especially on the freeway. What is the fix for this? I assume its an issue with the switches and not the transfer case since it will go back into a normal driving mode once its been reset.
