coolant type?
Porsche listed all fluids in their older cars owners manuals.
I have 2 928s and shall verify the coolant specs for the 5.4L V8 engine, which given the materials should be same for the Cayenne engine.
Received 5,416 Likes
Could also consider VW's coolant. Less $$ than Porsche's.
Sent from my iPhone using Rennlist
From the 928 GTS owners manual:
"only use phosphate free antifreeze containing ethylene glycol recommended for aluminium engines and radiators".
Lifetime Member
Lifetime Member
I would highly suggest using the OEM coolant. It is not that expensive when you consider you are replacing the coolant so infrequently.
The OEM is obligated to say "Use us", otherwise they'd have quite a crappy business model. Just look at what they recommend as replacements for the Cardan Shaft issues on these cars. More OEM Cardan Shaft parts! HA!
Lifetime Member
Lifetime Member
In other words: GM Dexcool or any other modern antifreeze will do. The OEM is obligated to say "Use us", otherwise they'd have quite a crappy business model. Just look at what they recommend as replacements for the Cardan Shaft issues on these cars. More OEM Cardan Shaft parts! HA!
Curious if their procurement model negotiates for VW, Audi and Porsche for economy of sale.
I used Pentosin brand antifreeze type PENTOFROST SF. I was able to purchase it at my local O'Reilley's for $12.99. I have an 06 CS. It seems that Pentosin makes the antifreeze for Porsche. Call/email them for their recommendation.
