2006 V6 Service Reset
Old 01-01-2015 | 07:14 AM
porsche3.2's Avatar
porsche3.2
Default 2006 V6 Service Reset
Hi,
How can I reset the service message please?
I've tried holding down the odometer button while ignition off and then keeping it pressed while turning ignition on, but dont get the service reset message.
Please help
Old 01-01-2015 | 07:46 AM
mcbit's Avatar
mcbit
Apparently this only worked on very early models before software updates were applied.
I think you need a Durametric tool or take it to an indy or a dealer.
Old 01-01-2015 | 08:40 AM
porsche3.2's Avatar
porsche3.2
Thanks.
Anyone tried the PS150 Xtool?
New XTOOL PS150 Oil Reset Tool OBDII Scanner for Porsche/BMW/Mercedes/Honda/Toyota/ Land Rover/Ford Oil reset,oil inspection: Amazon.co.uk: DIY & Tools New XTOOL PS150 Oil Reset Tool OBDII Scanner for Porsche/BMW/Mercedes/Honda/Toyota/ Land Rover/Ford Oil reset,oil inspection: Amazon.co.uk: DIY & Tools
Apparently it resets the service light and airbag etc..
thanks
Old 01-01-2015 | 09:25 AM
Km1.8t's Avatar
Km1.8t
Durametric tool is a good investment if you plan on keeping the car for a while. Saves a trip to the dealer for the reset and also allows you to read codes if needed.
Old 01-01-2015 | 01:50 PM
TomF's Avatar
TomF
Yes, the Durametric is a very good tool, (I use it on my 996 C4 Cab) with a caveat- it has challenges with the 957. It is not very useful at all on my '08. Earlier Cayennes are apparently fine, however.
Aloha,
TomF
Old 01-01-2015 | 05:26 PM
porsche3.2's Avatar
porsche3.2
Hi,
Anyone used this -
http://porschecable.com/
Seems to use the Durametric software?
Old 01-01-2015 | 05:52 PM
deekay911's Avatar
deekay911
Originally Posted by porsche3.2
Hi,
Anyone used this -
It's basically a knock-off of the Durametric cable. Search the web and ebay and you can find several variants of this, mostly from China, using the Durametric software. Beware though, many of them will be permanently disabled the first time you try to use it as the Durametric software can recognize non-original cables and zap them. Just pay the $250 and get the real thing, its worth it.
Old 01-01-2015 | 06:36 PM
Rossi's Avatar
Rossi
Are most independent shops able to reset the service message?
Quick Reply: 2006 V6 Service Reset
