Strong exhaust odor on start
Lifetime Member
Lifetime Member
After starting our 955, for about a minute or two there is a strong exhaust odor in the cockpit. Anyone have this issue, or know what this could be? It goes away after a few minutes, but initially it's fairly strong.
I've had my 04 TT for a year and a half. There is no odor inside the cockpit on start up. It is super-extra noisy for the first 20-30 seconds both from the engine compartment and exhaust while I assume it is getting to operation temperatures. After that point I can hear some sort of mechanism close and the noise from the engine bay gets cut down by about 80%.
I do leave the recirc setting on automatic. I'll try leaving it set to fresh air and see if I get the odor. Maybe some of this stuff is related?
Mine had something similar when I replaced a grenaded air pump. There was a piece of the air pump's fan jammed in the one-way valve keeping it open. Simple enough to diagnose, pull the pump start the engine and see if there is exhaust coming out. Fixing it is equally easy. Pull the one-way valve and remove the offending debris.
Lifetime Member
Lifetime Member
Moderator !x4
This can be a sign that the CAT's have issues, my 955 had that smell after a couple of nights in the garage.
Moderator !x4
Lifetime Member
Lifetime Member
Will replacing with Fabspeed cat bypass pipes correct this issue you think? Or is it likely the primary cats that are causing the odor?
Matt,
Ever find out why? I have a 2008 997TTCab with a Fabtech exhaust and it does the same thing for the first 30 seconds while the engines warms. Strong exhaust/gas odor comes from the car. Once the noise settles down the smell is gone. Lingers in the garage for a while and I am concerned for pets coming/going through there.
Lifetime Member
Lifetime Member
Matt,
