Typical Battery Replacement Cost is Now
Update: The Rest of the Story
Update: I had the battery replaced at the local long time Porsche-only independent. They put in an Interstate MTP 49/H8 and charged me $197.95 plus tax for the battery and $126 labor to install it.
For a related thread see https://rennlist.com/forums/porsche-...available.html posts 1, 7 and 15.
So far, so good (knocking on wooden head).
--Bob
--Bob
Very easy to replace the battery yourself as long as you have the proper tools. I would recommend that everyone own a set of the tripple square bits for many different repairs on the Cayenne. Does only take a few minutes to replace and I replaced it in the partking lot of Autozone on the last replacement. Save yourself some cash and jut buy a set of XZN bits.
http://richtoolsystems.com/index.php...F7waAsFj8P8HAQ
If you want a correct German battery and need it quick, Pep Boys and Advance Auto Parts offer Bosch batteries.
Well, ..it is a VERY heavy item.
Yes, you can dyi it, but beside the saving, you may add few physiotherapy sessions ...for lower back pain ! ..And reduce your back life time !
In my side, after 7 years of good and loyal services of my original battery, I decided that the Porsche dealer cost at around US$ 500 was OK for 5 years and 108'000 miles.
..much cheaper than gas per miles !
if you have the tools its a quick and fairly straightforward diy.
i was getting quotes anywhere from $129 - $300 for the battery depending on brand warranty etc.
should be no more than an hours labour at garage
