Rough idle after start when cold
Lifetime Member
Lifetime Member
For about a minute after starting when the engine is cold, it idles very rough. Should I be concerned?
Anyone have this issue?
I also seem to have a strong exhaust smell in the cabin after start for about a minute.
Thanks.
Thanks.
Check the coil packs for cracks, overnight moisture causes them to short out until they dry out a little.
If it is the coil pack it's a very common problem and easy (but not real cheap) to remedy. Last time I saw the pricing on coil pacs they were ~$45 ea, you only need to replace the cracked ones but that just means you my be going back in to do some of the other ones later.
It's been a while but the last rev. level I saw was .09, IIRC the ones in my '06 S were .03 when I got it.
