HID (headlight) D1S failure mode - odd one..
Old 10-28-2016, 10:15 AM
7 Summits
7 Summits's Avatar
One of the reasons I turn the DRL off is to extend the life of them. Have you tried pure methanol to clean them? I just bought some to clean the haze off the inside of the housings but am away for work. There is another thread about cleaning the inside of them with methanol.
Old 10-28-2016, 02:12 PM
deilenberger
deilenberger's Avatar
Received 1,149 Likes on 763 Posts
Originally Posted by Dilberto
OP - how did you "carefully" rinse this electrical part?
Rinse with the bulb facing down so moisture doesn't get into the electronics in the base. Dry with a microfiber cloth, final wipe with alcohol to remove any traces of moisture or finger oils.
Old 10-28-2016, 02:13 PM
deilenberger
I tried ethanol - "reagent grade" - ie 100% pure. It's MUCH cleaner than methanol. And it didn't touch the haze.
Old 10-28-2016, 03:20 PM
Dilberto
Dilberto's Avatar
So, you simply worked the rubbing compound in with a dry paper towel and the haze just buffed-out?
Old 10-28-2016, 03:46 PM
deilenberger
Damp rubbing compound. And I may have used a microfiber towel (cheap at Harbor Freight - about $0.50/each when they're on sale.. basically disposables.)
Quick Reply: HID (headlight) D1S failure mode - odd one..
