New 2015 Cayennes announced
#31
I am surprised with no mention of GTS, does it at least get the new exterior and interior? I actually don't mind the fact that it wasn't changed and remained (if not pulled) with V8, while S is now bi-turbo.
#32
EU gets a 22HP bumps, Panamera Diesel gets a 300HP Diesel version (0-60 in under 6 seconds, probably in Cayenne body would be under 6.5), and we get the same old under-powered engine and not even a V8D option?
#33
Told you so
Full model redesign at the earliest, but I wouldn't hold your breath for it until maybe the .2 of the next model.
Except that Audi and VW are already using higher outputs for the Q5, Q7, and T-Reg. My understanding is that it is the same V6 TDI we already have, just some tweaks. Regardless though, VAG already has a higher output V6 TDI in the NA market so regulative approval should be minimal.
As far as not having start/stop, that's a plus in my book. I will admit that it wasn't as bad as I expected in the loaner Benz I had while the P!g was at the dealer for a few days, was unpredictable (shutting off when I didn't expect it and not when I did) and annoying (my nightly commute has a lot of crawling so my foot was coming off the brake just as it shut off). I also just can't get over the idea of shutting the motor off when you aren't parking.
#34
I'm really not convinced with the look. Gen one seems less complicated and more balanced overall. Just mo. Only real improvement is the MF wheel. The rest meh. Kinda looks like a van now it's so squarish. From the rear it looks like a layered cake. Even the rear lights look an afterthought and don't hit the mark. I'm sure cost was involved in the design and that is what has left it looking like a tart up for the worse. They should have started with this new design and kept the last one as the update, and add some proper rear lights. That way it could be said as an "improved" design.
#35
Looks like one significant change to the diesel... The website indicates that PDCC is available now:
http://www.porsche.com/usa/models/ca...-control-pdcc/
Edit: Looks like it's probably just a mistake on the website. The German configurator doesn't list PDCC as an option for the Diesel
#36
Unless you find one in stock, no GTS. Same with the base. They'll both be back though as that is a normal release pattern for the Cayenne, Panamera, and now it would appear the Macan (release S and Turbo first, then come back and add the base, next is the GTS, and finally the TTS).
#37
Actually, when you look at the Audi page, both the Q5 and the current Q7 TDIs use the 240hp version in US. Same for VW Touareg. Maybe Porsche will change when the new Q7 comes mid of next year.
Same for me regarding the start-stop, but it can safe some diesel in the city. You could always switch it off, if you do not like it but would have the option to use it.
#38
(or it could just be a mistake, I guess we'll find out soon enough)
#39
I stand corrected. I could swear when the new T-Reg and refreshed Q7 came out that they bumped to 260/420. Maybe those were poorly converted Euro specs...
#40
Like seriously, what's the incentive for a CD owner to get a new one now? Absolutely no real benefit what so ever... "S" gets a power bump and better fuel econ, TT is faster and more frugal with more standard options, yet Diesel is the same and more expensive? Totally missed the mark!
#41
You are right, no real benefit. I got one of the very first ones in US in early September 2013, why would I trade in anyhow after two years. The car is perfect for the area I live in, strong from 0-35 mph but no high top speed, which I cannot use with the limits, anyhow.
Porsche did at least the such an engine change in Germany, change the Diesel within a model sequence, so I could imagine them doing it here as well, once they get the new engine with the higher volume Q7/ Touareg/Cayenne as a 2016 model.
Wondering what Mercedes fans will say that they are replacing the 350 bluetec with the 250 bluetec in US for the next model year (also no facelift as that will come in 2015).
#42
#43
Question on the tail lights... does it have the same shape/opening, so could it be retrofitted to 958.1?
#45
Sport Plus is now available as part of the Sport Chrono package. Makes it "snappier" and apparently retards PSM involvement.
Possibly on the fenders, but they appear to be longer and thinner on the tail gate to me.
