New and thinking of a Cayenne
Porsche (like all German cars but possibly more-so) strikes me as being the typical premium German product with solid engineering so the longevity should be good
I sense initial depreciation on these cars is pretty high which plays into someone in my positions hands but if the problem areas have been addressed and the maintenance has been properly looked after then it should still be a decent bet
The 955TT is the best value I have been able to identify in the used SUV market. They are selling in the $18-22 range with 65-75k miles and many owners have 140k+ miles. I paid $19 for mine with 71k. The biggest risk of purchase is piston scoring. This is mitigated by purchasing a turbo that has not seen cold weather starts. There is a list of standard repairs these cars typically have before 75k miles (found on this site) for which you would want to screen. If you live in a cold climate, you may want to look into an after market block heater. I believe the block heater was a euro option, maybe US too, but rare. Great daily driver. Blast to drive. Low acquisition cost. Potential for e35 type longevity. Go for it!
To clarify - you are referring to "miles" and not "kilometres"?
I agree with your sentiment from my research - the Turbo (& V6) uses Nikasil coatings on the bore which the other models do not which makes them largely trouble free from the cylinder bore issues
The list of "standard repairs" you mention - where can I find that?
I live in a cold climate and need to be sure that does not present any additional technical problems when the temperatures take a nosedive (the X5 was a disaster in the cold temps)
I installed an oil pan heater the X5 which probably helped and would install a block heater on any potential purchase for sure, but the problem I had was that the vehicle sat outside all day (not plugged in) and it always failed on my drive home so I need to be sure that the Porsche would not freeze up like the X5
Totally out of hand for me too - I like the vehicle but have zero faith in it anymore
Since you live where it gets cold, get a turbo. They have oil squirters for each piston. As for the common issues which most cayennes already have addressed:
Coolant pipes
Coolant Ts on turbos
Coil packs
Drive shaft
For under 30k you have the pick of the litter for 04-06 turbo. Look for a low mileage Turbo S that is still in your budget. Vroom Vroom.
Coolant pipes
Coil packs
Drive shaft
I had narrowed my choice down to a Turbo or GTS but while the Turbo has got to be mechanically more complicated (more to go wrong - particularly turbos) than the non turbo GTS it sounds like its still the better bet
I hadn't heard about the coolant T on the Turbo - can you elaborate?
Whats the difference between a Turbo and a Turbo S?
Is the "Cardan Shaft" a drive shaft? How does it fail? Worn out splines?
I`ve had times where I`ve wondered if the X5 was built in the dark with some of the issues Ive had
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
We haven't had any issues with cold temps.
Part of my travels take me up to Fort Mac and over to Toon Town in the deep winter.
After a night sitting out in the -40's she starts up without a whimper.
Quickly warms up and handles everything we throw at her.
We don't have any add on warming devices like battery blankets or oil warmers.
I should be crossing the 150k mark by month 36![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
So the Cayenne handles the cold just fine? Thats encouraging. I assume its sure footed in the snow too? Do you run winter & summer tyres or all seasons?
I own a X5 3.0i and a Cayenne Turbo, I really can't say that the Cayenne is any more reliable than the X5, each have their share of common problems.
Yes Sniffer you don't have to worry about the oil separator freezing like you do on the X5, I had that problem once before.
I do find the suspension on the Cayenne a little beefier and not as fragile as the X5, I run winter tires on both SUVs, it's like night and day with them.
I would find a used 955 Turbo that has updated coolant pipes, coils, coil packs, rear hatch struts, cardan shaft (another name for drive shaft, there is a center support bearing that fails often with the amount of power it takes).
Take a look at the suspension (front lower control arms, upper control arms, rear lower and upper arms,etc) and make sure nothing is seized for alignment, I had to replace almost all of mine as the bolts were seized in the bushings from our salty winters.
These SUVs like to eat tires and brakes, but you are probably used to that with the X5.
The Turbo S has larger intercoolers, larger front 2 piece brakes and a tune which results in 520hp. THey were only available 2006 and later. Except for the similar E81 pkg.
Here is some info on the coolant Ts.
https://rennlist.com/forums/porsche-...t-crapola.html
As for the cold. Mine came from Edmonton and is now in the Rockies. I now have 180000km and never a cold issue.
I've had a 05 X5 w/ 4.6 and now have a 06' Cayenne S and the CS is (kock on wood) WAY more reliable than the X5 was. I actually liked the X5 better to be honest, but the CS corners better and I don't get nervous every time I start it.
And don't get me started on the Range Rovers I've owned. All I can say is it's a darn good thing I don't take my cars in to get worked on. I'd have had to sold my house off to pay for the repairs.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
The Turbos also come with more options than the average non-turbo so your bang for the buck used goes much further.
I disagree too. There are several very nice 957 GTS for sale right now for $30k-ish. I bought a very nice one for $32k three months ago and am lovin it. 100% of Porsche body and structural steel is fully hot-dip galvanized on both sides, so they are ling lasting in the snow belts.
