any experience with these issues?
Hi folks.
recently got my 09 GTS and i <3 it. A few questions though, yes i've searched for solutions and now i'm reaching out to helpful members. My key fob eats a battery in about 5 hours. I imagine there's a short somewhere, so i've been thinking of purchasing a used one off of ebay and then having it cut&programmed at the local P dealer. Suggestions?
Also, my reverse camera is showing a grayed out screen. It'll flash an image fast as the camera opens, but then nothing. Something I can deal with but curious if anyone's experienced this. Lastly, my one headlight is out, but it appears to be one of the cheaper regular bulbs. Is this a daytime running light? it's not the highbeam or the bi-xenon. Thank you in advance!
As far as the camera goes it sounds like you have an intermittent connection issue. I had the same symptoms and it turned out to be the wiring going into the camera itself. Some troubleshooting time and solder fixed it...
