Oil Burn 06 Cayenne Turbo S
I figured out where all my oil was going
Air oil separator was bad and the check valve below it was bad
Take your check valve off and you should not be able to blow through it one way all 3 tubes on it
Have not lost any oil since replaced
My take is that in most cases, it's likely the check valve that's gone bad rather than the air/oil separator.
The check valve for an '06 Turbo is 948 107 219 50. What's weird is that the air/oil separator is not listed separately for the 955 Turbos (part of the valve cover), but is shown separately for the 957s. For the 957 Turbo, the air/oil separator is 948 107 236 52, but I have no idea if it can be used on the earlier generation Turbos. Anyone know?
I could not find the diaphragm for the separator and they wanted to sell me the whole valve cover so I got some high temp gasket maker and fixed it myself.
And here is the check valve I order
http://www.ecstuning.com/Porsche-200...ine/ES1441755/
While doing my cooling pipe swap, I saw some oil in the throttle body and in the pipes feeding it from the turbos. My thought was that the turbos are in need of a rebuild, but now I see this post and am not sure. Any help with diagnosis is appreciated.
It's completely normal to see oil in the charge pipes after the turbo. I'm not saying your turbos don't need a rebuild, but if you're only indication is some oil in the charge pipes and throttle body, then you may not have a problem. And, I'm not talking about just oil residue - you could pull the intercooler pipe and get a few ounces of oil spilling out. This is why some people install oil catch cans. This was also a common occurrence on the Audi 2.7 turbo motor - lots of oil in the intercoolers and lines. You could get almost a cup full out of those motors.
