Rear door ashtray replacements?
I have an '05 CTT and the little fliptop ashtrays in the back seat are all scratched up and are getting sticky. Any idea if I can just remove them (and if so, how?) or if I can get replacements from somewhere? I don't see them on Suncoast Parts, Pelican, etc.... any ideas?
I was looking for the replacement and found would be lot of work to replace them. Later some one told me the sticky stuff could be rub off. I did it by using some rubbing alcohol. The sticky went away and the tray cover as new in 5 minutes.
i don't know about other panels but the lighter door was broken when i bought my 06 ctts, thankfully it was the plastic housing and not the olive wood door itself that was damaged. 2 screws and a connector popped off the door assembly. i ordered a standard black plastic door replacement assembly, pulled the hinge pins, swapped the door and installed it all back in the pig. $42 for the black door assembly, over $400 had i bought the full olive replacement version. time to pull the housing, 4 minutes.... time to swap doors about 10.
i have the black plastic door and a few miscellaneous pieces that weren't needed. for free plus shipping should anyone want it.
