Dynavin head unit
Old Feb 15, 2014 | 01:35 AM
Dennis C's Avatar
Dennis C
Rocky Mountain High
Even with Bose? Would it use the factory GPS antenna? Factory mic?
Old Feb 21, 2014 | 11:56 PM
koolkat1973's Avatar
koolkat1973
I received the Dynavin DVN-PC from JT Distributor and have plugged it into my 06 CTTS w/ Bose to make sure everything works. So far - everything looks to be in good working order. Things are still laid out in the car at this point, but I will report back once I have everything installed neatly. At this point - it's looking very promising. I will try to take pictures along the way during my install in case anyone here is on the fence.
Kiet
Old Feb 22, 2014 | 01:04 PM
DavieGravy's Avatar
DavieGravy
I'm thinking I'll have to go this route. Does it have bluetooth audio and do you have to run any wires?
Old Feb 22, 2014 | 02:01 PM
Dennis C's Avatar
Dennis C
Rocky Mountain High
If it's truly "plug and play" and utilizes existing Bose amps, as well as the existing GPS antenna, then I may have to give it a try!
Old Feb 22, 2014 | 04:25 PM
drewcwsj's Avatar
drewcwsj
I am also very interested and am looking forwards to hearing about functionality and integration of this unit.
Old Feb 23, 2014 | 09:11 PM
koolkat1973
I have preliminary installed the unit and have it working somewhat. It's not 100% done as I am still awaiting the a fakra to rca connector so I can connect the OEM reverse camera to the unit. Yes - it does have bluetooth audio and I did not have to run any wires. All the necessary wires came with the unit. I have an 06 CTTS w/ the Bose system and it works like a charm so far.
Old Feb 23, 2014 | 09:13 PM
koolkat1973
It's almost truly plug and play. It has it's own GPS antenna so you have to use it's antenna. It comes w/ the MOST adapter so it works seamlessly with the existing Bose.
Old Feb 23, 2014 | 09:21 PM
jhg41977's Avatar
jhg41977
Do you retain the center instrument display?
Old Feb 23, 2014 | 09:26 PM
Dennis C's Avatar
Dennis C
Rocky Mountain High
How's the sound quality?
Old Feb 23, 2014 | 09:59 PM
koolkat1973
I'm not exactly sure what you're asking. Are you referring to the info above the tachometer? If so - you lose that bit of information.
Old Feb 23, 2014 | 10:00 PM
jhg41977's Avatar
jhg41977
Yes that is what I meant.
Old Feb 23, 2014 | 10:02 PM
koolkat1973
Sound is actually quite good. I will try to create a new thread with what I think about the unit as well as the some of the installation instruction. So far - it's definitely worth the money I spent. Being able to keep the OEM reverse camera functionality was a huge deciding factor for me. And it looks like I can do that. I have to get a fraka to rca connect for the backup video input and also need a relay to get the OEM camera to pop out when in reverse mode.
Old Feb 24, 2014 | 07:42 AM
virkdoc's Avatar
virkdoc
And how about the TRIP button info of the PCM? The one that shows time travelled/fuel economy etc?
Old Feb 24, 2014 | 08:59 AM
koolkat1973
You will lose that info with this unit.
Old Feb 24, 2014 | 09:01 AM
koolkat1973
Here is some not so great picture quality of my install. It's not 100% complete as I'm still waiting for my fraka connector.
