Tire inflating system did not work
I had low pressure on a tire, I wanted to inflate it with Cayenne Turbo's
own system. I found the air hose under the rear left passenger seat,
plugged it to the system under front passenger seat, turned the car on, but
it did not inflate the tire. Does anybody have any experience with this?
Just after I took delivery (almost 2 months ago) I tried the system and it worked great! I don't remember the details but I can recall the air compressor just humming away...
Make sure you screw it in tight, you should hear some air escape. When I use mine the TFT shows spare tire inflating, even though there is not one back there. It is easy not to screw it in straight.
