Cayenne vibration issue
Old 11-30-2013 | 10:35 PM
Houdan914's Avatar
Houdan914
3rd Gear
Default Cayenne vibration issue
At around 40 mph, our 06 Cayenne S begins to make a vibration shake that you can feel under the arm rest. Feels like its under the car and somewhere in the middle. 40 mph it starts and ends about 60 mph.
Anyone know what this may be?
Old 11-30-2013 | 11:29 PM
hahnmgh63's Avatar
hahnmgh63
Cardan(Drive) shaft?
Old 12-01-2013 | 12:02 AM
Houdan914's Avatar
Houdan914
3rd Gear
I am thinking drive shaft as well. Have not gotten it on a lift yet to inspect. Any known issues with these? Car has 94,000 miles.
Old 12-01-2013 | 12:06 AM
sprinky911's Avatar
sprinky911
very well known issue- just search here for cardon shaft! in fact just ordered my new parts last night because my at 87000 my is vibrating too- good luck!
Old 12-01-2013 | 01:54 AM
SCOTITUDE's Avatar
SCOTITUDE
read the stickys, you find all the info for whats gonna go wrong, including your cardan shaft bushing.
Old 12-01-2013 | 03:02 AM
Dennis C's Avatar
Dennis C
Rocky Mountain High
I agree with the others - it sounds like the cardan shaft.
Old 12-01-2013 | 07:19 AM
Orantes's Avatar
Orantes
Cardan shaft vibration usually doesn't end at higher speeds. It gets worse. You should check front wheel lower control arm bushings.
Old 12-01-2013 | 12:10 PM
Dyim's Avatar
Dyim
Rear tire out of balance?
Old 12-01-2013 | 02:55 PM
DWPC's Avatar
DWPC
A wheel imbalance will be felt in the steering wheel and through the floor and seat. If you feel it through the armrest, its almost certainly the Carden shaft bearing. It can be quickly diagnosed by a mechanic. Get it checked; if it fails, you'll need a tow truck.
Old 12-01-2013 | 06:47 PM
mtnrat's Avatar
mtnrat
Mine is beginning to vibrate. I am going to try the one piece driveshaft from Lindsey Racing.
http://www.lindseyracing.com/LR/Parts/955AXLE.html
Old 12-01-2013 | 09:05 PM
Dyim's Avatar
Dyim
I thought maybe only front wheel imbalance will be felt in the steering wheel?
Old 12-02-2013 | 04:13 AM
DenverSteve's Avatar
DenverSteve
Cardan issues usually occur during acceleration or deceleration not at a specific speed. Look at your lower control arm bushings. Could be several things.
Old 12-02-2013 | 01:44 PM
hahnmgh63's Avatar
hahnmgh63
On level ground, even at higher speeds under a light load the Cardan shaft can smooth out quite a bit. It is usually under higher Torque loads that the vibration occurs.
Old 12-02-2013 | 11:57 PM
Houdan914's Avatar
Houdan914
3rd Gear
Thanks to everyone who replied. Great folks here. Now it's research time for what kind of job the fix is. Whether it is a dealer fix or something I can manage safely through. Thanks again folks.
Old 12-03-2013 | 05:18 AM
Orantes's Avatar
Orantes
Cardan shaft or control arms....you can do both yourself. Few skills necessary!
Quick Reply: Cayenne vibration issue
