Reverse Camera Cover Won't Flip
Most good auto audio shops can do this install. I had front and rear cameras installed on my '13 Cayman S Cabriolet.
Hi guys! I have the same trouble now over 2 years. I also took my Turbo S to the dealer to get it fixed, but no chance. They told me that the plastic case is broken and need to be replaced by a new cam. Total damage would be 38 000MXN - about 1 900 USDs! I would not mind to buy a after market cam that works with the PCM. Any recommendations so far?
If the problem you have is the wormgear setup, they are easier to find than the camera electronics. Normally it's the camera unit that fails. The wormgear housing is most metal, are you talking about the hinged 'clamshell' case that bolts to the mechanical assembly?
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1167/depositphotos_254338590_stock_photo_rear_view_camera_of_porsche_4995d079d86bc6f8d1d8a0d623679b6ad49fc5f8.jpg)
