2004 Cayenne S dies soon after starting
I have a quote here parts alone - both pumps - totaling about $700 plus $100 for the fuel filter. Is that good for genuine Porsche parts but more importantly are these new pumps going to fail again as quickly as the old one??
My Cayenne S only has 45,000km (about 28,000 miles) on it .....![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Well mine went at 113k miles so that's a little better. Also I had been running the fuel low several times before the failure. I guess the pumps use fuel for cooling and so when you run the tanks low it causes the pumps to fail sooner. So just keep above 1/4 full and you should not have to do this again for many years.
Prior to failure, I was doing mostly really short runs in the morning when the engine was bone cold ... and no longer trips after.
One time, about a week prior to failure, it will not start in the middle of town (another short and unrelated trip). I yanked out the fuse for the ignition, put it right back in - and it started without an issue.
I would say I do run the gasoline tank to the fuel low warning light before I go fill up but I have been doing that for a number of years now?
So does that sound like a disaster in the making or what?
I guess I am trying to prevent it - if preventable - and you'd think Porsche would have known about this issue while testing the Cayenne in extreme heat, etc.?
