Rear windshield nozzle clogged?
Old Oct 9, 2013 | 05:53 PM
AdMan21's Avatar
AdMan21
Default Rear windshield nozzle clogged?
This morning I noticed my rear window was incredibly dirty. I pressed the lever to the nozzle in my new-to-me Cayenne to clear it out. I heard a popping noise..and noticed fluid dripping out of the upper panel closest to the tailgate (interior). Does this panel just pop off? should I remove the light first? Don't want to do too much damage here, everything seems dry now. Haven't tried the rear nozzle again though...but it did end up working.
I guess I just want to avoid another flood, I plan to remove the panel, remove the nozzle, and test it to see if there are any further leaks or maybe I just cleared out the blockage.
_RG
Old Oct 9, 2013 | 10:01 PM
S4Del's Avatar
S4Del
Same issue, I tried sticking a needle in there to clean it out to no avail, and just haven't bothered to try to figure out how to remove it completely.
Old Nov 16, 2013 | 11:00 PM
AdMan21's Avatar
AdMan21
thought about trying to tackle this again, removed the interior panel part-way, everything looks inaccessible behind metal..looks like I would have better luck removing the top of the rear spoiler, thoughts?
Old Nov 17, 2013 | 01:33 AM
Dennis C's Avatar
Dennis C
Rocky Mountain High
There was a TSB on this for Gen 1 Cayennes. The updated nozzle is red.
Old Nov 17, 2013 | 09:46 AM
AdMan21's Avatar
AdMan21
It does have a red nozzle, I'm thinking the line may be cracked? As it will stream out of the back, but also leak into the rear cabin top.
