Water Distributor Failure - 2008 CTT @ 50k miles
#31
In the tech notes section of last month's Excellence magazine, there's an in-depth discussion about the coolant distributor failures that have been plaguing the 957 Cayenne as well as certain 911 models. The bonding agent that is used to fit the hose pipe extension to the cast manifold fails under high heat conditions.
Also, there's the potential hazard of damaging certain transmission components after such a failure. An interesting read...
Thanks!
Best,
TomF
#33
Just wondering, for the 08 Turbo owners that have not had this happen yet, would it be a smart idea to remove high pressure fuel pump to get access and just apply JB weld onto the distributor and pipe to create more holding strength and hopefully prevent the separation in the future?
#34
Probably. I too have considered this or the route of adding a set screw to the fitting. There is a small possibility that the dealer may have already done this on my car...trying to get the record this week.
Best,
TomF
#35
Very bad news, I traced my faint coolant smell to the damn distributor pipe!! It has worked it's way out around 40% of the way, and I can clearly see the yellowish residue from a leak.
Ok, so this is where I need some help, how in a gods green earth did you manage to remove the high pressure pump? From what I can feel with my hand that barely fits in there, there are 3 bolts holding the pump down??
What type of wrench did you use, my smallest socket does not even fit in there.... Anything I should be carefull about when doing this procedure?
Any tips are appreciated!
In the mean time I cleaned the surface as much as I can and applied some JB weld on the distributor and the pipe so the pipe would not move out further...
I can't believe Porsche does not have this as a recall!
#36
Very sorry your having this problem. If you haven't already done so please file a safety report on this and hopefully eventually like the other coolant pipe people we shall get reimbursed for the cost of fixing this design flaw.
Go here to file your report there are already several listed on this same problem:
http://www-odi.nhtsa.dot.gov/owners/...rod_ids=421772
#40
#41
#42
Thanks for the link! I plan on doing the same thing to mine this next week.
Are you sure the pinning is not possible? Is the firewall or intake in the way to get a long drill bit / tap dow there? Mine is not leaking at the moment so I would like to do the fix before a disaster happens!
I like what Sharkwerks does to fix the problem. I was hoping to get a really long drill bit in there!
http://sharkwerks.com/porsche/techni...urbo-cars.html
#43
We are now at 5 formal reports on the NHTSA site over this issue and I would expect more since the '08's are now out of warranty and their owners will start to get hit with this expensive and possibly dangerous flaw.
#44
That fix looks nice but there is just no space in there to do that properly! The whole repair was a big pain, my hands were hurting for a week after this one! NOT FUN! We need the recall so Porsche can do this properly, which is to remove the water distributor and do a threaded solution.... The JB Weld option does seem to work well tho..
#45
One more failure to add to the list;
Cayenne S 2008
Pipe blew right out during a downshift, causing sudden coolant loss.
I've been told there is a newly designed water distributor with Part Number 94810606107. Apparently this time the outlet is threaded into the water distributor housing instead of just bonded in place. The way it should have been done initially.
Of course it seems the only way to get that part installed safely is by dropping the engine...
Thank you to the bean counters who decided to save $1 in this area despite knowing that it would compromise safety, brand integrity and customer satisfaction.
Has anyone had any luck yet tapping the thread from the top of the engine?
Cayenne S 2008
