When did the V8s become safe and sound?
Old 08-07-2013 | 05:51 PM
gruffalo's Avatar
gruffalo
Default When did the V8s become safe and sound?
Hi,
I've been looking at early cayenne S's and a lot of them have had the engine replaced, usually around 60k miles.
Rumors say that the engines were improved at some stage, around 2009. Is this the case?
How can I determine if the replacement engine is "good" or just as prone to failure as the original one?
For example, is there an engine number I can check for this?
I'm only familiar with 928s, and there are more than 20 variations of the M28 engine. Is this the case for the cayenne too?
Old 08-07-2013 | 06:32 PM
XR4Tim's Avatar
XR4Tim
Model year 2008 was the introduction of the 4.8, and I know of no mechanical failures with the 4.8. A certain percentage of 4.5s suffered cylinder wall scoring, particularly in colder climates.
Old 08-07-2013 | 06:49 PM
mudman2's Avatar
mudman2
Moderator !x4
the percentages on an 05+ MY is in your favor substantially, overall a great engine
Old 08-07-2013 | 11:55 PM
Dennis C's Avatar
Dennis C
Rocky Mountain High
Even the pre-2005 engines are quite good, especially once the coolant pipes are replaced.
Old 08-09-2013 | 11:44 AM
bigbuzuki's Avatar
bigbuzuki
2003 turbo, coolant pipes replaced.....engine has been bullet proof.
Old 08-12-2013 | 02:39 PM
Plastikos's Avatar
Plastikos
144K on mine, pipes went around 85K, I've just had the 'usual' issues otherwise (fuel pump, cardan shaft).
Old 08-12-2013 | 03:47 PM
mcbit's Avatar
mcbit
197k kms. on my old 05 CTT, no pipes replaced and no issues with the engine whatsoever.
Old 08-19-2013 | 09:19 PM
DenverSteve's Avatar
DenverSteve
As usual, many/most rumors are greatly exaggerated at best. Some had problems, most do not. Have anything you are preparing to buy checked out by a dealer prior to buying. Then, drive it like you stole it.
Old 08-20-2013 | 12:43 AM
Rickyuk's Avatar
Rickyuk
Mine is a 2004S with 111000 miles. Ordered cooling pipe kit for peace of mind. Engine does not use any oil and so long as I treat the car with respect and regularly maintain it I do not have any issues. Love the car. It is a well designed sports SUV with power and comfort.
Quick Reply: When did the V8s become safe and sound?
