Squeaking panorama roof
This one saved me. I was hating my Panoramic until this. I used a Felt pad on the drives side at first and it took about half the sound away. I then went back a few weeks later and added another to the drives side and one to the Passenger side and it is all quiet now. This word needs to get out to everyone with the Panoramic. I lubricated my tracks, seals, felt pads under the headliner this was all I needed. The sound never sounded like it was coming from the two front corners, it always sounded like it was more centralized. What a relief.
I hope the fix lasts!
Cheers,
TomF
It works! The squeaking and creaking were really beginning to take their toll on me and sucking a high level of enjoyment out of driving the Cayenne. Did the fix documented via link in post #12, and it took away at least 80% of the noise. Some of the remaining sound may actually be due to the other things I had tried previously. Now I may need to go back and remove the ~50 pieces of felt scattered across the entire front of the sunroof!
Cheers,
TomF
Thanks!
No squeaks and the Pano roof operates flawlessly. Sometimes when the seals stick together, the roof computer gets confused and shuts it down. Ten minutes and no problems.
Cheers,
TomF
