Random Seat Memory
Random Seat Memory
I’ve had four Cayennes now and all three have had very random seat memory.
Am I the only one who experiences this? I use the same key all the time and I have ‘auto memory store` turned off.
About 1 time in 4 that I get in the car the seat will assume a random comedy position. I can press and hold the stored memory button and it goes to the right place every time.
What am I doing wrong? Or is this what all Cayennes do?
I've only had the 1 Cayenne and I've never had that happen, of course I'm pretty much the only one who drives it. I do have to move it forward before I can lay down or raise back up the rear seat and the driver's seat goes back to it's assigned position.
I think it’s something to do with the comfort entry option. The seat moves back and steering wheel rises as you open the driver’s door and it’s supposed to return to the right position when you get back in the car.
Sometimes it does! I suppose that’s better than not at all.
What I do is put the key fob into its slot - which starts the seat return movement - then reach for the seat belt. By the time I have the seat belt fastened, the forward movement has completed. Only then do I start the car.
//greg//
It's very random. I can tell you that I had Cayenne that did that all the time and other never.
Very weird. Porsche could not answer this question.
What I could recommend you to try, is memorize your SET 1 or 2, while doors are closed and engine is running.
I have the same irritating problem with the seat memory on my 2012 Cayenne S. When I get in and insert the key, the seat may or may not return to the previous position. If this is user-error, then someone please tell me the secret.
