958 Interior Door Panel Removal
Hi guys, I was wondering if anyone had instructions on how to remove the interior door panel on a 2012 Cayenne? Was driving a friend home the other day since he was drunk...long story short ..he had to puke, no time to stop so we opened the window..95% went out side, another 5% stayed inside...along the b pillar and some inside the window edge..I need to get the door panel off to clean it. Any advice is appreciated, thank you.
I might dig out a couple of pics somewhere... or maybe not.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
http://www.6speedonline.com/forums/c...5-yeeeahh.html
Just did my tint last night. That door panel is a pain in the ***!
Assuming you're talking about the front door panel. There's a screw behind a cover at the base of the door handle. A screw behind the inside door handle behind the cover next to the door unlock/lock buttons. More screws under the arm rest. Remove the arm rest by using a plastic trim pry tool pulling in an upward motion. And four or five screws behind the horizontal trim piece on the upper part of the interior door panel. Trim piece can be pried off with a plastic trim pry tool. After getting all screws off, you can pry the interior door panel off. Clips are holding it tight so don't be scared to pull hard.
someone threw up in the 911, i sold it...
idk about you guys but even cleaning it damn well.. the smell never goes away when the car is out in the hot sun...
as far as the above video with mercedes, i dont even know how that car worked after the fact! people here are timid with which trickle charger they use... and he's pressure washing the interior!
