Warning 957 Cardan Shaft and Horns Replaced
The cardan shaft failed in my 2010 GTS at 48.5K miles. Also, test your horns, there is a design defect that allows water to seep into the contacts that corrodes them. I've experienced this on two 2010 957's. My passenger seat airbag and seat sensors were also replaced, this seems to be anotber common failure, at least according to my SA. Thank goodness I was still under my OEM warranty, otherwise $3K.
