Any progress on the LED trailer light issue?
Old Feb 7, 2013 | 10:10 PM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
Default Any progress on the LED trailer light issue?
OK, I know very well Porsche hasn't admitted there's anything wrong with their setup, I was wondering if any aftermarket supplier has come up with an adapter that allows us to use U-Haul trailers (w/ LED lights) with these things? I thought there was a 7 pin round to 4 prong flat that had some resistors built in that allowed the lights to function. I checked 3 auto parts stores but none knew what I was talking about, neither did U-Haul.
I tried to rent a trailer at U-Haul this afternoon, trailer had LED lights. The brake lights worked fine but the tail lights and turn signals just blinked real dimly the whole time (even with the P!g turned off and key removed the trailer lights continued to blink rapidly). Couldn't use the trailer because I'll be driving about 1400 mi., much of it at night.
I know we have several trailer light threads, I was hoping there was some new info.
Fortunately I have my trailer (w/ std. bulbs) that works fine, it's just bigger and heavier than I need for this trip. Oh well, at least I have a backup.
Old Feb 8, 2013 | 08:54 AM
grohgreg's Avatar
grohgreg
Clarification please; I installed a seven blade connector on my '13 CD. You wrote "seven pin" connector. Both are round. It makes a difference when you're shopping for an adapter. I also have a 7-blade to 4 pin adapter. That said, none of my 3 trailers have LED lighting, so I can't help in that area. Sorry.
//greg//
Old Feb 8, 2013 | 02:38 PM
Mike in CA's Avatar
Mike in CA
25 Year Member
Bill, I installed a Pollak 7 way blade connector on my 2011 Cayenne. Can't guarantee it would be the same for your '06 but I got the info on the Pollak from a thread that was referencing earlier Peppers so I think it would work.
http://www.amazon.com/gp/product/B00...ls_o01_s00_i00
Then I bought the adaptor in the pics below. It's made by Valley but was available through a VW/Audi dealer; can't recall which one. I do remember that the dealer web site listed part numbers for Tourareg and Q7 models which are interchangeable with the Cayenne. I've pulled equipment rental and U-Haul trailers with both regular and LED lights with no problems. It even deactivates my backup sensors and activates appropriate warning lights in my instrument display.
File Type: jpg
File Type: jpg
Old Feb 9, 2013 | 10:13 AM
Frank 993 C4S's Avatar
Frank 993 C4S
I tried the same adapter on in my '10 and it does not work with UHaul LED light trailers. For whatever reasons, the brake lights didn't work. Maybe it now works for the newer models.
Old Feb 9, 2013 | 12:38 PM
Doug_B_928's Avatar
Doug_B_928
I'm thinking about getting this one:
http://www.etrailer.com/Wiring/Curt/C57003.html
Note that it also comes in a 7-4pin
Old Feb 9, 2013 | 04:04 PM
Mike in CA's Avatar
Mike in CA
25 Year Member
They worked fine for me....must have been a change, as you say.
Old Feb 9, 2013 | 07:29 PM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
Mike, outstanding! I'll look for one of those. I have the same style (and yes I meant 7 blade to 4 pin flat, I was concerned more with the LED issue) but it doesn't do anything about the LED load.
Crazy thing with the 7 blade to 4 pin flat I've used since I got the P!G is the brake lights were the only thing that did work connected to the U-Haul!
//greg//
Yeah, Greg, I was concentrating on the LED side of the issue, it is a 7 blade round to 4 pin flat adapter that we need for most common trailer lights. See Mike's version above.
Old Feb 10, 2013 | 09:57 PM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
Having a heck of a time finding the Valley above but I did find this site, maybe the brand is Valley, we'll see. Ordering it now.
Old Feb 11, 2013 | 09:37 AM
scott40's Avatar
scott40
This adapter works. I have it on my '11 CS. I trailer a Trailex with LED. Brake lights, back up sensors, etc. all work fine. However, if the Cayenne is off and the trailer is still plugged in, the lights on the trailer will intermittently blink. My solution is to just unplug the trailer when parked at the track or elsewhere. I doubt the battery drain is very much, but I do it anyway.
Old Feb 11, 2013 | 11:15 AM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
I noticed that too with the U-haul connected to my '06 w/ the basic 7 blade to 4 pin flat adapter, they blinked very rapidly even with all lights off and the key removed. Strange. If it still does it with the new LED adapter I'll just unplug too.
Old Feb 11, 2013 | 03:00 PM
Mike in CA's Avatar
Mike in CA
25 Year Member
Looks similar Bill, hope it works for you. When I bought mine over a year ago I also had a heck of a time finding the Valley piece. Word at the time was they were moving their manufacturing plant and product distribution was disrupted, but I was able to eventually find a VW dealer that stocked it under their part number. I would have thought they would have had it resolved by now, assuming they are still in business.
I haven't noticed that. I'll have to pay more attention next time I trailer.
Old Feb 11, 2013 | 06:54 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
What trailer light issue?
Old Feb 12, 2013 | 03:59 PM
Toby Pennycuff's Avatar
Toby Pennycuff
Cue the squirrels, please..........
Old Feb 13, 2013 | 12:01 AM
Budget M3's Avatar
Budget M3
Got mine at the local VW dealer. It was a Valley part. My vintage travel trailer with incandescent lighting works perfectly and my cargo trailer with LED's only blinks when the truck is shutoff.....makes for a nice theft deterrent! I have left it plugged in overnight with no problems.
Lewis--Glad to see that you finally solved your Cayenne trailer issue--No Cayenne, No Issue!
Old Feb 13, 2013 | 07:25 AM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
I don't see how you can associate the unexplained sudden "disappearance" of Larry's Cayenne (which IIRC PCNA lawyers stated in no uncertain terms would never be purchased back by PCNA since there was no issue) with any sort of solution.
Clearly there can't be a solution where there is no problem....there wasn't even a trial
