Are Cayenne turbos water-cooled like Audi's?
The single engine issue I had on my Audi was the aux cooling pump for the water-cooled turbos. I haven't found any mechanical details or diagrams for the V8 turbo engine that say if the turbos are w/c or not.
From the General Servicing & Repair book:
"To cool the turbochargers while the engine is not running, the electric coolant circulation pump, which is installed behind the wheel house cover at the left front, can be switched on. The electric coolant circulation pump is switched on as needed in run-on operation together with the electric cooling fans by the DME control module."
Cool, thanks. Used to cars that have it always running after driving for a bit, but I never hear it on mine. Just metal pinging from material contraction and air compressor noises.
When I drove an Audi 2.7T, the aux cooling pump ran frequently after parking in the garage. I've never heard it run in my CTT; even in an AZ summer.
