20 x 10 or 20 x 8.5 and what tire size?
Old 12-14-2012, 11:36 AM
Doug_B_928
Doug_B_928's Avatar
Default 20 x 10 or 20 x 8.5 and what tire size?
I'm ready to pull the trigger on some wheels and tires for my 08S. I've decided on the 20" Victor Zehn in hypersilver and the Continental DWS (I want the all season so they last longer). Different dealers seem to stock either 10" or 8.5" wide Zehns. Which is the best size to get? How would the appearance be different? What tire size (275; 295) would look and work best with each? I'm a little concerned with the 10" on a 275. This is primarly my wife's car and the rims WILL NEED sidewall protection from curbs TIA
Old 12-14-2012, 12:13 PM
carcommander
carcommander's Avatar
I don't think I would put custom wheels and tires a vehicle where curbs are commonly hit. Why put yourself through that agony?
Old 12-14-2012, 12:15 PM
kosmo
kosmo's Avatar
I would go 295s. thats what i have but on 21"s. Just make sure you get a load rating of at least 109. Our PIGs are, well, heavy.
Old 12-14-2012, 12:29 PM
Cole
Cole's Avatar
Fwiw, when I showed my wife that her car had the "curb view" auto tilt right mirror option all the curb rash suddenly vanished from her wheels and has not appeared on the new set.
Old 12-14-2012, 03:58 PM
Doug_B_928
Doug_B_928's Avatar
Curb view is already on and, to her credit, she has become very careful (she loves her P!G). But I wouldn't want the rim to stick out past, or be flush with, the tire sidewall.
Old 12-14-2012, 05:16 PM
Slow Guy
Slow Guy's Avatar
Some models of tires have the "rim rib"(?) to help protect the wheel.
Old 12-15-2012, 12:30 PM
Doug_B_928
Doug_B_928's Avatar
Good to know. What is the difference in appearance between the 10" and 8.5"?
Old 12-15-2012, 02:35 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,276 Likes on 801 Posts
I believe the OEM 20" wheel is a 20x9. At least this is the case for my Cayenne. I run 275 width tires on these wheels, per factory recommendations.
FWIW - I run 265 width tires on 18x10 wheels for the winter tires on my C4S, per Porsche recommendations. The 265 doesn't look too narrow for a 10" wheel.
Old 12-15-2012, 03:00 PM
Budget M3
Budget M3's Avatar
IMHO, your concern about damaging the wheel is justified--a 10" will give her little margin for error.
Equally concerning, however, is a 275 on an 8.5" rim. Most tire experts recommend a minimum wheel width of 9" for a 275 width tire. You can mount a 275 on an 8.5" wheel, but the sidewall will be subject to more roll which could be unsafe in an emergency handling situation.
If it were my choice, I'd go with the 10" and 275 and live with the inevitable curb rash.
Old 12-17-2012, 11:43 AM
Doug_B_928
Doug_B_928's Avatar
Thanks guys! Sounds like the it would be safe to go with 10" and 295s. Kosmo has 295s on 21s, but not sure what MY he has. How can I check to make sure that the aforementioned combo will work fine on an 08S (no rubbing etc.)?
Old 01-27-2013, 10:42 PM
Doug_B_928
Doug_B_928's Avatar
I ended up with 275/40/20 Continental DWS on 10" wide Victor Zehn rims. In case anyone searches, so that you aren't in the position I was of not seeing pics of these wheels in a 20", I have attached a couple below. I love them! I have winters on but had to put these ones on just to see how they look. The 275s do stick out past the wheel well just ever so slightly, but it looks good.
Old 01-28-2013, 12:46 PM
Dstinson
Dstinson's Avatar
Doug- Thank you for the pictures and information! Your Cayenne looks great with the Zehns! I just ordered the 10" Victor Zehn rims in Black for my 2006 Pig and have a new set of 275/40/20 Pirellis (Summers) waiting to be mounted to them. You answered several questions I had about with this set up. Do you have any pictures direct on from the rear or front to show the over all width of the tires on these rims? I was wondering about the over all width, look and handling aspects these wheels provide with this wider set up. Should have mine in a week or two.
Old 01-28-2013, 12:54 PM
Doug_B_928
Doug_B_928's Avatar
I don't have good direct front/back pics, sorry. I was concerned about a rougher ride. While it is a little rougher compared to the 18's, I found the ride not too bad at all. Post some pics when you get them on.
Old 01-28-2013, 12:56 PM
Dstinson
Dstinson's Avatar
Will do...Thank you!
Old 02-16-2013, 02:31 PM
Dstinson
Dstinson's Avatar
Getting there. Now I just need summer to get them mounted up. Still snow on the ground here in Germany.
Quick Reply: 20 x 10 or 20 x 8.5 and what tire size?
