08 Cayenne start problems!
Old Dec 11, 2012 | 07:49 PM
raidy31's Avatar
raidy31
Exclamation 08 Cayenne start problems!
Hi..this is my first thread on this forum.I have a 08 Cayenne, lately I have noticed it needs to turn a few times in order to start up. Has anyone else noticed this cranking issue when performing a cold or hot start? Anything to be concerned about?...Sorry about my bad english!!!..thanks
Old Dec 11, 2012 | 09:15 PM
User 4221's Avatar
User 4221
Is it worse immediately following a fuel-up?
If so, then it is likely the tank vent or purge valve. Both are covered in this forum. A quick search will find it.
Old Dec 15, 2012 | 09:03 PM
deilenberger's Avatar
deilenberger
And it might be worth checking the fuel rail pressure - especially the retained pressure (after the engine is shut down.) Had similar problem when I got mine.. a complete set of fuel pumps, pressure regulator and filter assembly later it starts flawlessly (thank Dog for CPO..)
Old Dec 15, 2012 | 10:38 PM
ALEV8's Avatar
ALEV8
Mine still does this intermittently....and after the new coils and plugs heaven.......I've developed a crappier idle than before, lately. Not looking forward to a starter or fuel pumps.
Old Dec 16, 2012 | 12:00 PM
vnta7's Avatar
vnta7
4th Gear
If I remember correctly the manual recommended to replace the drive belt when you change your plugs otherwise the car might develop this start up problem.
