Do 911 Spacers Fit Our Cayennes?
Hi all
Do spacers for the 911 / Boxster fit correctly on the 955 CTT? I have the option to buy some genuine Porsche 17mm spacers with part no 996-361-617-00 and wonder if they are correct for my Cayenne or not?
The seller has offered to throw in a set of closed cup wheel nuts, if they fit is this all i would need? Am i right in saying that my existing bolts are used to fix these spacers to the hubs then the wheels mount onto these and are fixed by the nuts?
There are also options available online for Techart 18mm spacers, again listed as being for 911's or Boxters etc rather than the Cayenne, does our truck take a different spacer or are they all the same?
I have 20" factory 20" Cayenne Sport 9J wheels front and back, hence want to push the rears out a bit. I also think the fronts could do with some movement also as i have GTS style arch extensions which add to the narrow look.
Carl
Carl
