Wheel Ratings For Cayenne
Hi all
What are the load rating requirements if buying none genuine wheels for a CTT please?
Would i be right in thinking 735kg per corner is not really enough?
Carl
Carl
The ones i saw were 20" and rated at 735kg for each wheel which isnt as high as others i have seen at 900kg. The axle weight on the CTT would put the 735kg rims at their max wouldn't it?
I have a set of the "Design" wheels (9x19"), a set of "Sport Techno" (9x20"Fr & 10x20"Rr), and set of BBS RXII (10.5x21") and I just inspected all of them and couldn't find a weight limit stamped unless it is in some kind of code. For the tires for example, the 19" are Continental 4x4 Sport Contacts (275/45-19) and list a 1000KG rating, the 20" are Hankook Ventus RH07 (275/40-20) and list 950KG, the 21" are Michelin Latitude Sport (295/35-21) and list 975Kg. All are XL weight rated tires, I would say that the wheels should exceed the tire specs in all cases. Where did you get the specs you found?
