1st oil change in Cayenne Diesel
#63
Engine performance isn’t affected with or without the stuff so the age my Adblue doesn’t matter to me. Keeping current with the Adblue only matters if there is emission testing and critical when the low level warning lights up and there are a limited number of engine starts remaining.
I should be getting mine soon too.
#64
//greg//
#65
The only time when you need to clean out the adblue tank is when people screw up and spill when filling the tank incorrectly. Urea will crystallize in absence of water. I have not seen a proper service procedure write up for servicing adblue in dealerships. My proper DIY solution.
https://rennlist.com/forums/9928472-post4.html
#66
Porsche R&D develops a revolutionary "oil sensor technology" but decides only to implement it in diesel and hybrid gasoline engines, which happens to be the smallest selling volumes in their lineup, so they can amortize this development cost over a longer period of time? Current service indicators run on a mileage or time limit; whichever comes first.
#67
Here some interesting notes on Adblue from a company that makes diesels too...Cummins.
Q. What is the freeze point of DEF?
A. A 32.5% solution of DEF will begin to crystallize and freeze at 12 deg F (-11 deg C). At 32.5%, both the urea and water will freeze at the same rate, ensuring that as it thaws, the fluid does not become diluted, or over concentrated. The freezing and unthawing of DEF will not cause degradation of the product.
Q. What is the shelf life of DEF?
A. The shelf life of DEF is a function of ambient storage temperature. DEF will degrade over time depending on temperature and exposure to sun light. Expectations for shelf life as defined by ISO Spec 22241-3 are the minimum expectations for shelf life when stored at constant temperatures. If stored between 10 and 90 deg F, shelf life will easily be one year. If the maximum temperature does not exceed approximately 75 deg F for an extended period of time, the shelf life will be two years.
#68
Late Porkchops
When we were looking at the Cayenne diesel for Mrs TR the dealers service tech and service rep who had just returned from the Porsche Certified Training told me that
1.) Porsche changed the oil service intervals to 5,000 miles for the US delivered Cayenne diesels.
2.) That that the AdBlue DEF would be serviced at the 10,000 services due to the shelf life. He stated that the tank would be drained and refilled.
Beings a diesel guy from way way back, and of coure familiar with the AdBlue and having the Ford product right here in the shop it raised my eyebrows. Of course getting at the tank and the refill neck was not all that easy for my wife
As for the oil changes, it is Porsche, so what was I going to do about it. I assume if you dont perform the Maintainance per the Porsche schedule then you are doing so at your peril.
These are expensive rides. They are not inexpensive to maintain. You know that going in to the purchase.
You dont even want to think about a denied warranty claim down the road for failure to follow the Porsche Maintainance Schedule. A quick glance back in these forums tells you that you could NEED that warranty.
Besides all of that , oil changes are about nothing compared to the depreciation of a Cayenne, or any other similar vehicle.
#69
Here is the MSDS for Adblue. It is a chemically stable product. Precipitate forms below 50 degrees Celcius. While it is recommended that product should not be stored for a long time, there is no definite expiration date.
#70
Thanks. Too many unsupported Chicken Little stories going around about the new CD. I'm not buying that 5000 mile oil change interval either. I will follow my 2013 maintenance manual until I receive info directly from Porsche to do otherwise.
//greg//
//greg//
#71
I flush my brakes every two years and it is a closed system. Regular maintenance is a good to to our cars and I advocate that. I am not saying the adblue tank does not need to be serviced but just be well informed so you don't also pay for blinker fluid at the same time.
#72
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
I hope this helps. I was seeing the conficting info as well. Maint. Manual does not specify every 5k miles. But everything else I have "Heard" says 5k miles. So my Pcar dealer printed this up for me.
Porsche NA should send out an "Insert" to put in your manual. I am not sure if they are required to, but they better get on it! Audi does it often.
Notice the Publication date. My CD was built in July, sold in October, so I am sure the manuals were not updated.
Come on Porsche NA, get it together and send out an aftersales maint. insert!!
#73
The oil change interval for CD in the US market is 5000 miles. You'll find that after the oil change service interval is reset, it goes back to 5000. Though you might look through your MFI and see oil change, intermediate and main maintenances listed at different intervals, you're still going to have an oil change every 5000 between those services.
Additionally the OE Retail bottles of AdBlue state "Dispose product after two years from production date"
It seems to be a universal agreement that DEF should be replaced after two years. See:
http://www.discoverdef.com
even GM states it expires (page two)
GM Fleet & Commercial DEF info
From Cummins:
http://www.cumminsfiltration.com/pdf...es/MB10033.pdf
"Q. What is the shelf life of DEF?
A. The shelf life of DEF is a function of ambient storage temperature. DEF will degrade over time depending on temperature and exposure to sun light. Expectations for shelf life as defined by ISO Spec 22241-3 are the minimum expectations for shelf life when stored at constant temperatures. If stored between 10 and 90 deg F, shelf life will easily be one year. If the maximum temperature does not exceed approximately 75 deg F for an extended period of time, the shelf life will be two years."
so... perhaps it's some evil plot to get you to buy more of it, or maybe some part of it actually breaks down chemically...(which is my vote, because some resources state a shorter shelf life for DEF stored continuously above 90f.)
Additionally... with reguard to draining vs sucking, having sucked and then drained a 3.0 petrol powered supercharged engine (ala hybrid) the difference was maybe 2 ounces if you let it trickle out for an hour. These engines are designed to have the oil changed via extraction.
From Cummins:
#74
Here are a couple YouTube videos on AdBlue - technology & refilling. Although they are VW/Audi and Mercedes Benz, they are very representative of the system used by Porsche diesels. The second video (Merc) is quite instructive IMO.
Refilling AdBlue is not a dealer task unless you require draining and or other service of the AdBlue system ...
A search of YouTube for AdBlue results in several additional informational and marketing videos.
#75
My dealer told me that as part of the oil change, they fill up the Ad-Blue.
