1st oil change in Cayenne Diesel
No argument with the second recommendation, but why pay a qualified independent to simply change oil? The high school dropouts at Grease Monkey can at least operate an oil suction device, change a filter, and pour in the amount of oil you give them. It's not rocket science, it's simple economics.
//greg//
//greg//
I agree, it should be (and is really) a simple job but they can really foul it up.
Second issue (for me at least) is they're in such a hurry to do the job in "15 min. or less" they don't let all the old oil drain out before they close it up and start installing the new oil.
Just my .02.
//greg//
//greg//
The point is, how many of the "high school dropouts" are going to be familiar with oil changes or anything else in a Cayenne, gas or diesel, and do you really want them to practice on yours? I don't. Just sayin'.....
If you want to talk economics, real savings, and being sure the job is done right, consider doing your own oil changes (see the link below).
https://rennlist.com/forums/cayenne-...-pictures.html
//greg//
I read the 5k interval here so I asked my dealer about it when I picked mine up last week. He referred me to the maintenance guide which says 10k. He also asked his tech who just got back from training on the diesels and he said the same.
I'll do my first at 5k, then after that it will be every 7-10. If my local shop wants $300, that'll be plenty on incentive to do it myself...
//greg//
Yes, the CD has an easily accessible dipstick tube (capped) in the right front corner of the engine. And if you review my suggestion, I clearly mentioned supplying your own C30 oil and Porsche approved filter. For me it's a 200 mile round trip to have my Porsche dealer change the oil for $300. But Grease Monkey is a 50 mile round trip and $35 (plus oil and filter). Like I said, a no-brainer.
//greg//
//greg//
Irrespective of the differences between the CD and V8, having someone work on my car who probably rarely sees a Porsche much less works on one, and more importantly, whose primary goal is to complete the job as quickly as humanly possible, causes me concern. Your comfort level with this is clearly different than mine.
That said, on principle, I wouldn't pay $300 and travel 100 miles (round trip to my dealer) for an oil change either, which is why I do my own (it's a 100' round trip
7th Gear
Personally I would rather drive an hour to my dealership and have the service done by trained mechanics than teach a jiffy lube employee about the ins and outs of a BRAND NEW 2013 Diesel Porsche. I did not buy a new Porsche to take it to a quick change shop - don't get me wrong - when I had my Honda jiffy lube was by best friend. However, this car is different - and new to me. I am not happy at all with the over fill light on...still. Eventhough the mechanics at Porsche are trained on the new diesel it still seems to remain a mystery. Frustrated.
I'll still change it more frequently though as I just don't trust these long intervals MFGs are pushing. Maybe I'm gun shy from seeing a few engines fail due to bad oil change practices in the pre-synth days, but even dealer prices every 3-5k is cheap insurance against a burned out engine in my book. Our 996 has a 15k interval if I remember correctly, but it's been changed every 5-7k or once a year which means there were maybe 5 that didn't need to happen. I don't think I could pick up a good condition engine for $800ish
More frequent oil changes also means you (or someone you hopefully trust) is under the vehicle more frequently and can hopefully spot problems before they go south. It was an oil change that actually alerted us to both our RMS failures (the tech noticed the telltale "single" drip) and waiting another 7-10k could have very easily been a new engine.
I recall reading somewhere, but don't recall where, that the sucking method, well, sucks at getting out potential impurities compared to letting them run out of the bottom of the sump with the oil. Thoughts?
My thought is that you drive into the quick lube place, they almost immediately stick the suction tube down the dipstick tube after shutting down the engine, and suck out some amount of oil. IMO, there's no way that they are going to extract all of the dirty oil that you'd get by letting the engine drain down for 30 minutes. Not only might this leave dirty oil in the engine, it could also be problematic as to how much oil to have them add back in, with the possibility of overfill. I guess I'm just too obsessive about this kind of thing.....
//greg//
My .02, marine mechanics have been doing the "evacuation" method for years (not too easy getting a drain pain under an engine in the bilge area) but then again marine engines (v8, v6's) have been "marineized" (correct term?) so where the dipstick tube ends and how much of the oil gets sucked out I don't know. I just have to believe older design (car) engines with the tube to measure oil level don't go all the way to the bottom of the pan. It's also very possible mfgrs. (inc. Porsche) are moving in this direction with the "capped tube" system that Greg has and the tube is designed to evacuate more of the oil, I see that as a very real possibility esp. if they've moved the oil filter to the top of the engine for easy "one location" maintenance.
Is it critical to get every last drop of old oil out? Not in my opinion. I doubt many shops let it drain for more than 2 - 3 min. before they plug it back up (personally I let it drain for 15 min + but I'm incredibly ****...). With 9 qts. + I don't think it's that critical to get every drop. In my 993 there's no way you could get all the old oil out unless you disassembled the oil cooler lines in front of the RF tire. On that car a oil change leaves ~1.5 qt. of old oil in the system, I don't lose sleep over it. As long as the oil is changed when it's warm the impurities are "suspended" in the oil and will come out with the old oil.
Personally, with the quality of today's oils I've long since abandoned the 3 - 5k oil change frequency. Does it hurt to change it that often, absolutely not, I just don't need to do it. I'm personally happy w/ 7,500 mi. (w/ VERY high quality oil) but wouldn't worry if it had to go to 10k (I've never gone that far though). I'm still not comfortable w/ the 15k changes and probably never will be, too many internet pics of gummed up engines for me to go that far. I'll most likely have Blackstone test my oil during my next 7,500 mi. change just to see how it's doing (don't have a baseline to compare with though).
Since Greg's "Grease Monkeys" aren't getting anywhere near his drain plug I (personally) wouldn't have a problem letting them do the job but then again I'd be buying my own evac. system to do it myself, as I said, I'm ****. I have a small evac. system now that I use to change the oil in the mowers, pressure washer and even the motorcycle, it works very well ($20 at Lowes) (wouldn't work for a car though!).
Important thing is to change it, and keep records in case Porsche needs to see them later (heaven forbid).
Just my .02.
Addendum: The Nashville dealership only carries 2 oils (both 55 gal. drums). They are (as of last year) M1 0w40 and Pennzoil 5w40. This is because they are a Sonic dealership and that what Sonic buys. I don't like either oil. They have a central oil station where the tech dials in the amount of oil from which brand and then it's pumped into a 1 gal. (?) funneled container. The system isn't close to being exact. They're building a new dealership (with new service facilities), maybe they'll have a better system in place there?
I'm sure they've had to add a different oil for the new diesels but I don't know how or what it is (I missed the last tech. session there).
Just my .02.
I strongly suggest you read up on oil changes in your owner manual. It's almost unthinkable - given the technology of the engine/oil/filters - that you'd have to change every 5k. Unlike the gasoline only Porsche models, the diesel and the hybrid engines have oil quality sensors. Other than changing the break-in oil on you diesel @5k, you don't have to change again until the car computer tells you. Mine says 5k right now, followed by another @20k - unless my driving habits make the computer tell me otherwise.
All this by the way, is predicated on your using C30 oil and Porsche-approved filters. The warranty does NOT necessitate it be done at a Porsche dealer. If you provide the correct oil and filter, there's no reason you can't have it done at any quick change place for $35 - or whatever the going rate is these days.
//greg//
//greg//
Well, at least you read your owners manual...
Hmmm, let's see... $35 for some kid who doesn't even have a GED and is known for screwing up Hondas, or $40 for a Porsche trained mechanic with a reputation to protect.....which one do I pick??
It will likely dismay you to know then, that many dealerships - including Porsche - are moving to this same system. They suck it out from the top. Don't think for a minute that they replace the oil with individual liter bottles either, they pump fresh oil in through a refill hose connected to a 55 gallon drum. Unless they spend the extra bucks for a system that can meter to 0.1 liter, it's not unreasonable to expect an occasional over-fill.
//greg//
//greg//
In any event, if what you say about many Porsche dealerships oil change proceedures is true, then I am dismayed
