How much must a rim clear the caliper?
Hi Everyone,
I have a 2013 Cayenne GTS. It came with the black GTS turbo 21" rims. I purchased 19" rims with snow tires from Tirerack. I just put them on and had a question. How much should the rim clear the caliper from the flat edge where "Porsche" is stamped? There was quite a clearance with the 21" wheels. The new front rims clear the flat edge of the front caliper by about 1/4" (the rears are fine).
BTW for anyone changing tires from 21" to 19" on a 2013 Cayenne with a side skirt, you can only use the Porsche jack on one side. After that, the screw drive for the Porsche jack will grind into your side skirt and chew it up.
Thanks,
Sam
Thanks,
Sam
Any clearance from the wheel to the caliper is okay because it won't change. If it does, then the rim is seriously bent.
It's common to use a hockey puck between the lifting point and the jack to prevent problems. Get a proper floor jack and use the supplied scissor jack for emergencies only.
