Bad Xenon Leveling Sensors
Mine was doing the same thing, cleaned contacts several times, no change. Read in another thread that old light bulbs can cause this problem so I ordered new D1S (?) bulbs, finally installed them the other day, have only turned the headlights on a few times and no errors. It had been happening almost every time so I'm hopeful, just not ready to say it's fixed yet.
Update: New bulbs did NOT fix the problem. I'll be replacing the leveling sensors as soon as I figure out which ones to replace.
How many sensors are there on a '06 S w/ Xenon lights? At one time I think I read there were 2, 1 front and 1 rear but when I called a dealer he indicated there were 4, which is true?
I just fixed my 06 S with the Check Dipped Beam issue. Turns out that one of the Xenon (D1S) bulbs was failing. If you check HID failure on the Internet, you'll note that a lot of these bulbs tend to start to cause problems from vehicles with model years from 04 through 06.
After changing both bulbs (real Sylvania from Amazon at about $95/pair) no problems at all.
My 2 cents.
My 2 cents.
