Block heater
#31
There actually was a pre-heater w/ Timer option as a factory option:
7VE Pre Heater w/ Timer
Heats engine coolant and circulates to the
heater core to warm the passenger
compartment and defrost the windows.
#32
//greg//
#33
//greg//
lkraav (08-07-2022)
#35
#36
Hope this helps. Driver side fender well. Shots with fender on and off.
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/webasto_heater_far_shot_af751ecf91e2f5d65f500876a6c8236623aeb35a.jpg)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/1104x1136/parking_heater_no_fender_1_2ed6af8e2abae13fcaeac5fe350f45f312e68f94.jpg)
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/824x1136/parking_heater_no_fender_2_823347c95a8b669e2c8f0de7e68ec60e8bffc101.jpg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/webasto_heater_location_f851a0275655ac60d0e2c0ce04b6da026a4c2a43.jpg)
Outer pipes are coolant in and out to engine. Center pipe is exhaust that exits under car.
Here's a link to a you tube video I did of the operation of the heater. Couple minutes long.
lkraav (08-07-2022)
#41
Thanks very much Jeff! That is some very cool engineering. I wish I had that option on my 2009 CTTS. Our place in the mountains regularly sees 60+ inches of snow and temps in the single digits and that option would be helpful on those incredibly cold days...
#42
Originally Posted by TomF
Great! I am really curious about how it all fits in there and works. Thanks!
#43
Regrettably, I don't have one. I wish I had that option... I have wondered how they work and as some others on the board have mentioned, if one could be retrofitted.
#44
Well anything is possible. You have to pull engine and then route the new lines (well maybe with engine in but wow that would suck). Then out one climate head unit.
Perhaps you could just install the aftermarket version from Europe.
#45
Hello,
Anyway went through the options and ordered DEFA 412802 which is a model specific element for Cayenne V8. And also a 4A charger and 2kW cabin heater to match. All works with one plug, of course.
Just put that to google picture search and you'll see how small it actually is. Unfortunately it is for 230VAC (Scandinavia, most of Europe) and I do not know if it is available for 115VAC. Basically you could just hook it up to lover voltage safely but then the power would be halved also. Price here is in range of 100€ / 120$
Tumpelo
Tumpelo
Indy shop warns me about frying oil risk.
