Block heater
Hello,
First proper winter days in Finland for a long time and my 2004 Cayenne S refused to start. Turns over just fine but does not fire up properly. Temp was -29 Celcius / -20F. Not that cold for a gasoline engine...
Had to take bike to work (only 3 miles).![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Anyway went through the options and ordered DEFA 412802 which is a model specific element for Cayenne V8. And also a 4A charger and 2kW cabin heater to match. All works with one plug, of course.
Just put that to google picture search and you'll see how small it actually is. Unfortunately it is for 230VAC (Scandinavia, most of Europe) and I do not know if it is available for 115VAC. Basically you could just hook it up to lover voltage safely but then the power would be halved also. Price here is in range of 100€ / 120$
Winter greetings from Finland.
Tumpelo
Tumpelo
lkraav (08-07-2022)
I'm trying to figure out where people would use these? Do people not have garages or heated garages?
It can get to -40C here, but I would never not keep my Cayenne in the garage!
lkraav (08-07-2022)
LOL. I have a better car in my garage as well as my wife's, so no room. I do have a large shed covered on 3 sides that houses a boat, my landcruiser, bobcat for snow removal, ride em mower and the cayenne. No heat and is the same temp as outside so it would be nice to have a block heater. Much better for the engine. I still don't understand why there is no accommodation for heating the engine some way. Are any other mainstream SUV's like this. I would like to know.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
The proper solution is a Webasto, I looked at getting one but wimped out at potential costs and fear that if not properly installed it could wreak all sorts of havoc on the Cayenne`s temperamental electrics
I did install an oil pan heater. As others have said there is no easy "good" place. The lowest part of the oil pan (i.e. beside the oil drain plug) is ribbed and its quite small. I spoke with Wolverine who suggested "Steelstick" which filled in between the ribs, I then sanded it totally flat before fitting a small round heater that just fits.
Its probably undersized but as I see it thats got to be better than nothing. Whatever heat it generates coupled with the fact that it lives in our garage as much as possible is the best I can hope for.
On a side note I changed the oil recently (around 9000 Kilometres since last change) and I noticed a definite difference in getting the oil up to temperature. The old oil came up to full operating temp quite a bit faster (0W 40 before and after)
What the ***, Cayenne in garage? You are not supposed to garage daily drivers / off roaders. Garage gets muddy![nono](https://rennlist.com/forums/graemlins/nono.gif)
Anyway, left an industrial heater under hood over night and got the big C started this morning. With huge "smoke&steam". Started with half block first and then slowly picked up left bank also. Interesting.
Can't say if it had wetted the plugs or just did not get fuel. There was no smell yesterday while starting so maybe I need to check the fuel system. I heard that it should be rock solid in these but you never know
![](https://rennlist.com/forums/images/buttons/viewpost.gif)
I've got to admit i am surprised there isn't an option for pre-heat the engines on these vehicles. Surely Porsche expected the Cayenne to be used all year around, and in some cold places.
Driving over the Bow River bridge this morning, the river was steaming as it was -20C outside. Car is garaged, but when i park at work it would be nice to use the plug in stations during the day.
Diesel is another story.... Does the Diesel Cayenne's have a heater option?
Put a pan heater on my old Mercedes diesel, and several of my diesel tractors. But never yet have I been tempted to install one on the Cayenne. I attribute that to Tier IV electronic fuel injection and very high common rail fuel pressure.
//greg//
