Parking Sensor Help
Parking Sensor Help
I was wondering if anyone has had this issue before and knows how to fix it. i have an orage light that says on all the time in the front parking sensor indicator (see pics). anyone know how to make it go away? the parking sensors appear to be working fine. Thaks for your help
Be sure to clean each sensor and sensor cup really well. A soft tooth brush and warm solution of car wash is best. Any small bit of dirt, bug guts, dust, old dry wax or even water spots can cause problems. Even if you think it looks clean, clean it again. Be sure to check if any paint is missing from the surface of the sensor as this can also create issues. I had the same issue and a with a good detailed cleaning they work like new.
