Driver Side Door not closing properly?
Old 07-26-2012 | 06:10 AM
mikeymike79's Avatar
mikeymike79
Default Driver Side Door not closing properly?
Has anyone experienced the following problem?
When I close the drivers door, it sometimes doesn't shut properly. In order to get it to shut, I have to close it especially softly.
Really frustrating. Before I take it to get checked, does anyone have a similar experience or know of a quick fix?
Old 07-26-2012 | 09:29 AM
Andy E.'s Avatar
Andy E.
The V8 Porschephile
Do you experience the problem when the windows are open? If so, quite normal since the doors are double-gasketed and create an air-tite seal.
Another possibility is that you may have to adjust the door strike on the jamb (B-pillar).
Old 07-26-2012 | 08:28 PM
mikeymike79
Problem is with windows closed. Haven't tried it with windows open yet. I'll check the door strike... seems like it is a little stuck... maybe it just needs some oil?
Old 07-26-2012 | 11:21 PM
99firehawk's Avatar
99firehawk
U need to install a shim in the hinge pretty common on early cayennes
Old 07-27-2012 | 03:09 PM
mikeymike79
What is a shim?
Old 07-27-2012 | 10:36 PM
99firehawk's Avatar
99firehawk
http://www.paragon-products.com/Door...531.483.00.htm
Old 07-28-2012 | 08:25 AM
Nhirsch's Avatar
Nhirsch
Originally Posted by mikeymike79
What is a shim?
a spacer typically same shape as the piece that it's shimming.
Quick Reply: Driver Side Door not closing properly?
