Check Brake Lights Indicator
The indicator light came on. I purchased new bulbs, swapped them out and the darned indicator light is still on. I've verified that all bulbs at the back of the vehicle work properly.
Any input?
Thanks.
Any input?
Thanks.
Try cleaning the contact surfaces on the bulb receptacle. A (clean) pencil eraser can clean off any corrosion, give the computer a clear electrical signal and maybe clear the warning. I did that on my '04 CS when I was getting erroneous cornering light warnings and it did the trick. Probably would work on brake lights as well if the bulb is OK.
