Hissing from brakes/vents
Starting a couple days ago, on a grueling ride to the beach, my car started hissing out of the driver side A/C vent and brake pedal. The hissing sounds like air slowly being let out of a tire.... ssssssssssss....
Both A/C and brakes function properly.
I have searched "hiss", "vent", "brake", etc. but don't come up with any results in the Cayenne forum.
Anyone know what this could be, or an easy fix for this, without involving a dealership/shop?
Thanks!
Thanks!
Strange.. since the brakes and vents have nothing to do with one another. It can be difficult to localize these types of sounds. My best guess is a leaking brake booster since it is under pressure and located under the dash and through the firewall.
That is just an educated guess.
yes it's strange. The sound initially started coming out of the vents. Then over the last day or so started coming from the brake pedal area. In fact, it sounds like it's the brake pedal itself, or right behind it like you said.
Its either a cobra in your dash or a leak from a vacuum operated device, example a HVAC actuator flap.
Next time it happens try changing the direction of the air (floor, center, etc.).
UPDATE: Turns out the sound was coming from behind the brake pedal. Dealership diagnosed as a leaking brake booster. $1212.24 + tax installed. $430.99/parts, $781.25/labor.
The weird thing is this didn't throw any code and the brakes seem to operate fine. I don't know if they will progressively get worse over the next week, but they feel fine now. The work is scheduled for next Friday as they couldn't get a loaner until then. The only consolation is that the loaners are 2012 Panameras
So much for MTBF (mean time between failures).
Dam, I was kinda hoping to try out my new snake lasso.
Next time you at the dealer have um look at the center shaft bearing
support for the drive shaft.
And, save some bucks down the road, don't spill any coffee or soda's
on the shift console. The tiptronic magnet mat is such a silly design.
Update: I canceled service. I really don't have 1213 to spend on a car that is still running. It pretty much has to be doa for me to drop that kinda cash on a car. If I had that kind of money I would have bought a new 911 or something. I am just going to keep hissing until something changes in the performance or function of the brakes. Until then, ksssssss cobra style.
I would be careful ignoring a leaking brake booster. That is what creates pressure for your braking system. It might be mild now, but it would make me paranoid... we are ultimately talking about a safety issue here.
