Cayenne 955 Hood Crest
05-17-2012, 03:47 PM
OK, so how do I get to the 2 speed nuts on the back of the hood crest to change it!
TIA
05-17-2012, 03:55 PM
Admin Lifetime Rennlist Member
05-17-2012, 04:24 PM
How do I get to the back of the badge? I tried an 8mm wobble socket, thats somewhere inside the front PU now, you just cant get to the 2 nuts! Do you take the front upper latch area cover off?
Its a turbo so may be a bigger grille in the front PU than the S cars
Dont tell me its a PU off job?
05-18-2012, 12:26 PM
No one on here ever changed a hood crest on a pig?
05-18-2012, 01:06 PM
The V8 PorschephileRennlist Member
Quote:
Originally Posted by
911PERVY
O.K., we won't tell you....but it is.
Front apron must be removed on the S or V6. With the Turbo, you may be able to access it via the front grille.
05-18-2012, 01:49 PM
Bollox................but thanks, fingers cut to **** trying to get through the grille, think I need a gynecologists touch
05-18-2012, 04:38 PM
I loosen the top of the cover and was able to get my hands in to change mine. Wasn't that hard to do but it will leave a mark on your arms.
05-18-2012, 07:57 PM
911PERVY
Maybe you need the right tools too!
05-19-2012, 05:05 AM
nineoneone
I loosened all the top screws and could pull the PU off about an inch, still cant get my sausage hands in there! How much did you loosen yours?
05-22-2012, 03:19 PM
I pulled all the screws out. It opened enough for me, tight yes but I was determined.
955 ,
airbag ,
badge ,
black ,
cayenne ,
crest ,
diy ,
ecu ,
forum ,
front ,
grill ,
hood ,
removal ,
remove ,
replace ,
turbo
