2006 cayenne s, regarding 2/4 wheel drive switch
Old 05-15-2012 | 08:33 PM
Edward 96 Viper GTS's Avatar
Edward 96 Viper GTS
Default 2006 cayenne s, regarding 2/4 wheel drive switch
Should any of the 2/4 wheel drive switch lights be on? Referring to the console area behind shift ****.
Ed
Old 05-16-2012 | 01:38 AM
deilenberger's Avatar
deilenberger
Umm.. they're not 2/4 wheel drive - it's full time 4WD with the option of locking the front/rear and a high-low range.
And no - none should be on normally. Pull the lever toward you several times and see if the lights go out (stopped, engine running, in neutral or park..)
Old 05-16-2012 | 01:55 AM
Edward 96 Viper GTS
No lights are on now or light up when I pull on the lever.....
Also, may have been in the "lock" position as I heard a "grinding" sound when I hit a dip at about 50 mph. Weird, disturbing sound only on the particular down hill dip. Any thoughts?
Ed
Old 05-16-2012 | 09:00 AM
mudman2's Avatar
mudman2
Moderator !x4
Doubt its anything to do with the switch position, which is only active, stopped and in neutral. I would suspect something else.
Quick Reply: 2006 cayenne s, regarding 2/4 wheel drive switch
